[OpenLayers-Dev] jslint cleanup committed
Paul Spencer pspencer at dmsolutions.ca
Fri Oct 19 15:35:15 EDT 2007
19 instances, not 29.  Next, I will get a calculator and learn to
add ...
On 19-Oct-07, at 3:33 PM, Paul Spencer wrote:
> For those of you that are not on IRC, Tim and I worked this out
> this afternoon and I committed:
> http://trac.openlayers.org/changeset/5028
> which cleans up some 29 instances of local scope variables used
> without 'var', making them global in scope. This is now part of my
> regularly scheduled routine :)
> Cheers
> Paul
> On 19-Oct-07, at 1:30 PM, Tim Schaub wrote:
>> Hey-
>> Paul Spencer wrote:
>>> for the record, I did fix the above warnings in Rico/* and did
>>> NOT touch
>>> firebug.  As Tim indicates, it doesn't affect the final build.
>>> As of
>>> now, the final full build is 'lint free' with my current
>>> settings, which
>>> makes me very happy :)  I may look at some of the other settings
>>> to see
>>> if there is anything else we could potentially benefit from in
>>> the newer
>>> version of jslint which I discovered last night ...
>> Paul, I'd also be interested in the result of disallowing use of
>> undefined variables.  Perhaps you already talked about this and I
>> missed it.
>> What would be really cool is if jslint could be tweaked to look for
>> variable assignment outside of the OpenLayers namespace -
>> something we
>> occasionally stumble across and have no way of testing for.  (I
>> know a
>> case where window.i == 2 and I cannot figure out why.)  This might
>> even
>> be caught by the "no undefined variables" filter if it is initialized
>> without the var keyword (which is likely).
>> Tim
>>> Cheers
>>> Paul
>>> |Paul Spencer                          pspencer at dmsolutions.ca    |
>>> |Chief Technology Officer                                         |
>>> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
>>> !DSPAM:4033,4718de8133771961014482!
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
