[OpenLayers-Dev] Fwd: [OpenLayers-Commits] r4148 - in
	trunk/openlayers/tests: . Handler
    Eric Lemoine
    eric.c2c at gmail.com
    Sat Sep  1 10:11:36 EDT 2007
Hi
In case this was missed, I added tests for the Feature Handler a while back.
<http://trac.openlayers.org/ticket/891>
Eric
---------- Forwarded message ----------
From: commits at openlayers.org <commits at openlayers.org>
Date: Aug 31, 2007 1:56 AM
Subject: [OpenLayers-Commits] r4148 - in trunk/openlayers/tests: . Handler
To: commits at openlayers.org
Author: tschaub
Date: 2007-08-30 19:56:04 -0400 (Thu, 30 Aug 2007)
New Revision: 4148
Added:
   trunk/openlayers/tests/Handler/test_Feature.html
   trunk/openlayers/tests/list-tests.html
adding basic tests for the feature handler
Added: trunk/openlayers/tests/Handler/test_Feature.html
--- trunk/openlayers/tests/Handler/test_Feature.html
         (rev 0)
+++ trunk/openlayers/tests/Handler/test_Feature.html    2007-08-30
23:56:04 UTC (rev 4148)
@@ -0,0 +1,88 @@
+<html>
+<head>
+  <script src="../../lib/OpenLayers.js"></script>
+  <script type="text/javascript">
+    function test_Handler_Feature_constructor(t) {
+        t.plan(4);
+        var control = new OpenLayers.Control();
+        control.id = Math.random();
+        var layer = "boo";
+        var callbacks = {foo: "bar"};
+        var options = {bar: "foo"};
+        var oldInit = OpenLayers.Handler.prototype.initialize;
+        OpenLayers.Handler.prototype.initialize = function(con, call, opt) {
+            t.eq(con.id, control.id,
+                 "constructor calls parent with the correct control");
+            t.eq(call, callbacks,
+                 "constructor calls parent with the correct callbacks");
+            t.eq(opt, options,
+                 "constructor calls parent with the correct options");
+        var handler = new OpenLayers.Handler.Feature(control, layer,
+                                                     callbacks, options);
+        t.eq(handler.layer, "boo",
+             "layer property properly set");
+        OpenLayers.Handler.prototype.initialize = oldInit;
+    function test_Handler_Feature_activate(t) {
+        t.plan(4);
+        var map = new OpenLayers.Map('map');
+        map.addControl(control);
+        var layer = new OpenLayers.Layer();
+        map.addLayer(layer);
+        var handler = new OpenLayers.Handler.Feature(control, layer);
+        handler.active = true;
+        var activated = handler.activate();
+        t.ok(!activated,
+             "activate returns false if the handler was already active");
+        handler.active = false;
+        var zIndex = layer.div.style.zIndex;
+        activated = handler.activate();
+        t.ok(activated,
+             "activate returns true if the handler was not already active");
+        t.eq(handler.layerIndex, zIndex,
+             "layerIndex property properly set");
+        t.eq(parseInt(layer.div.style.zIndex),
+             map.Z_INDEX_BASE['Popup'] - 1,
+             "layer z-index properly adjusted");
+    function test_Handler_Feature_deactivate(t) {
+        t.plan(3);
+        var deactivated = handler.deactivate();
+        t.ok(!deactivated,
+             "deactivate returns false if the handler was not already active");
+        handler.layerIndex = Math.floor(Math.random() * 10);
+        deactivated = handler.deactivate();
+        t.ok(deactivated,
+             "deactivate returns true if the handler was active already");
+             handler.layerIndex,
+             "deactivate sets the layer z-index back");
+  </script>
+</head>
+<body>
+    <div id="map" style="width: 300px; height: 150px;"/>
+</body>
+</html>
Modified: trunk/openlayers/tests/list-tests.html
--- trunk/openlayers/tests/list-tests.html      2007-08-30 23:25:49
UTC (rev 4147)
+++ trunk/openlayers/tests/list-tests.html      2007-08-30 23:56:04
UTC (rev 4148)
@@ -71,6 +71,7 @@
     <li>Control/test_Permalink.html</li>
     <li>Control/test_Scale.html</li>
     <li>test_Handler.html</li>
+    <li>Handler/test_Feature.html</li>
     <li>Handler/test_MouseWheel.html</li>
     <li>Handler/test_Keyboard.html</li>
     <li>Handler/test_Drag.html</li>
Commits mailing list
Commits at openlayers.org
http://openlayers.org/mailman/listinfo/commits
More information about the Dev
