[OpenLayers-Dev] OpenLayers.Format.KML.write()
Christopher Schmidt crschmidt at metacarta.com
Tue Sep 4 10:40:47 EDT 2007
On Tue, Sep 04, 2007 at 04:28:52PM +0200, Damien Corpataux wrote:
> Hi Tim,
> I just posted a patch on ticket #927. The patch suits the requirements:
> - KML extends XML
> - XML class methods are used for XML manipulation
> - tested on FF2/Linux and IE7
> - KML.write() returns a string (using XML.write())
> - GGE import of OL exported KML is working, and vice-versa
Looks pretty good. Any chance you could write some tests for KML.write()
-- just a few simple ones, to confirm it works?
Christopher Schmidt
More information about the Dev mailing list
