[OpenLayers-Dev] OpenLayers.Format.KML.write()
Damien Corpataux damien.corpataux at camptocamp.com
Wed Sep 5 08:40:12 EDT 2007
Christopher Schmidt wrote:
> On Wed, Sep 05, 2007 at 12:27:09PM +0200, Damien Corpataux wrote:
>> Hi Christopher,
>> Thanks for the stub! It got me into writing the tests (very quick).
>> Everything's fine on ff2, but a problem occurs on IE7 (only when running
>> the tests, not on using the component within OL).
>> I put all the information and patch into the ticket, which I now wonder
>> whether it's a good idea, http://trac.openlayers.org/ticket/927#comment:5
>> Anybody might have ran into a similar problem with test.anotherway?
> Interesting. I'll see if I can figure out why: The GML tests should be
> using something similar, and they don't have any problems I'm aware of.
> Regards,
Unfortunately, test_GML.html doesn't test GML.write() and GML and is not
yet using XML class methods for Doc manipulation... I wish I could help
a little further, but I think my knowledge of Test.AnotherWay is too
limited to rapidly make out what's going on... :\
http://trac.openlayers.org/browser/trunk/openlayers/tests/Format/test_GML.html
http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Format/GML.js
Regards,
Damien
Camptocamp SA
Damien Corpataux
PSE A
CH-1015 Lausanne
+41 21 619 10 22 (Direct)
+41 21 619 10 10 (Centrale)
+41 21 619 10 00 (Fax)
P Please consider the environment
Do you really need to print this email?
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070905/584c0657/attachment.html
More information about the Dev mailing list
