[OpenLayers-Dev] Marker Vector Trouble
Graf, David dgraf at progeny.net
Mon Sep 10 14:26:35 EDT 2007
I have a Vector Layer and a Marker Layer on a map.  I'm having
difficulty getting the features from the vector layer to match up with
the markers in the marker layer. Meaning that if I set up a marker with
a LonLat and give the same LonLat to the feature from the vector layer
they don't end up in the same spot on the map.  And when zooming in the
two objects get farther way and zooming in the objects become closer
until they are at the same spot.  I am thoroughly confused as to why
there should be a problem like this.
Thanks,
- Dave
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070910/f10ba67e/attachment.html
More information about the Dev mailing list
