[OpenLayers-Dev] [OpenLayers-Users] Handler problems
Christopher Schmidt crschmidt at metacarta.com
Wed Sep 12 14:31:37 EDT 2007
On Tue, Sep 04, 2007 at 09:39:08AM +0100, Tom (JDi Solutions) wrote:
> In this example there is one further change from the example above.  The
> handler has been changed from Box to Point.  Now if you shift click the map
> the co-ords are displayed below the map as before, if you then shift click
> outside the map div the co-ords are recalculated and displayed.  This should
> not happen!  Further clicks outside the map do not trigger the handler.
> http://demo.jdi-consult.net/oltest/custom-control-point.html
> Can someone please confirm this, is there a quick fix?  Shall I add it to
> JIRA?
I could reproduce before, iirc, but I can't anymore. can you try
checking out trunk and seeing if this is still happening for you?
I can reproduce it on your page above, but not against
http://openlayers.org/dev/examples/custom-control-point.html which is
the same thing, but against trunk, afaik.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
