[OpenLayers-Dev] Problem with Firefox on Navtoolbar
Antonio Volpicelli volpicelli at oato.inaf.it
Fri Sep 14 06:20:58 EDT 2007
Hi devs,
I am trying to use NavToolbar Control but seems that it doesn't work
fine on Firefox and Opera
It seems that the active area when I click is not on the arrow images.
For the UP arrow the active area is some pixels at bottom right of the
arrow image.
For the DOWN arrow it is at top right of the arrow image
The LEFT arrows doesn't work at all
The RIGHT arrow works fine.
So I tried the live example
http://www.openlayers.org/dev/examples/navtoolbar.html and this has the
same problem.
It works fine with IE.
Are there someone that know why?
Thanks
Antonio
More information about the Dev mailing list
