[OpenLayers-Dev] BBOX values are out of range for EPSG:4326
pdecker paulad at rmi.net
Tue Sep 25 11:03:55 EDT 2007
My zoom level was not high enough.   I adjusted that and now the correct
bounding boxes are being requested from OpenLayers.  Thanks.
Christopher Schmidt-4 wrote:
> On Mon, Sep 24, 2007 at 08:05:02AM -0700, pdecker wrote:
>> Hello,
>> I am running example: controls.html which is found in the examples
>> directory
>> of OpenLayers2.3.
> http://openlayers.org/dev/examples/controls.html
> should be fundamentally the same: I don't see any requests outside the
> bounds of the world. Do you? (Tryign to figure out what I'm missing.)
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
View this message in context: http://www.nabble.com/BBOX-values-are-out-of-range-for-EPSG%3A4326-tf4509740.html#a12881570
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
