[OpenLayers-Dev] VML Rendering of point data
fporcelli at taic.net fporcelli at taic.net
Tue Sep 25 11:25:34 EDT 2007
Hello dev --
I was wondering if anyone is aware of an issue discovered regarding rendering of KML point data using IE6. It seems the point locations are not placed at the correct coordinates when using the VML renderer with IE6. After some research I noticed that there was a documented issue in ticket #517 (http://trac.openlayers.org/ticket/517) regarding the inability to use floating point numbers in VML. It appears that this is directly related to the above issue. While this ticket is closed, is anyone aware that VML point data still is not rendering correctly? If a patch is required, I would be happy to offer up some assistance, but don't have write access to the code base.
Thanks,
Frank
More information about the Dev mailing list
