[OpenLayers-Dev] Patch for a ka-Map cached layer
Pedro Simonetti Garcia pedrosimonetti at gmail.com
Wed Apr 16 10:18:04 EDT 2008
Paul,
As you suggested, I've updated the file structure. Here comes the updated
patch. As I stated in the earlier post, I'm using the same configuration
file "config.php" for the "tile.php" and "precache.php". The "config.php"
file is in the tracker of the issue #327.
[1] http://trac.openlayers.org/ticket/327
Sould I add this file to the new ticket I'm opening? I'm not doing this to
avoid duplicities in the tracker.
The ticket for this patch is:
http://trac.openlayers.org/ticket/1518
My best regards,
Pedro Simonetti.
2008/4/11, Paul Spencer <pspencer at dmsolutions.ca>:
> On 10-Apr-08, at 10:05 PM, Pedro Simonetti wrote:
> > Hey Paul,
> > Thanks for your response.
> > Just to make it clear, so the structure [1] is the best one (one more
> > directory level)?
> > [1] var/cache/World/50000/Group_Name/def/t-440320/l20480
> > [2] var/cache/World/50000/Group_Name/def/t-440320l20480
> > If so, I'll have to make this little modifications in the patches/files
> > I've
> > sended here, and in the earlier post. But this is easy, just confirm if
> > the
> > first one is the best.
> The first one is better than the second one for sure.  I wouldn't go so
> far as to say it is the best ;)
> Cheers
> Paul
> __________________________________________
>   Paul Spencer
>   Chief Technology Officer
>   DM Solutions Group Inc
>   http://www.dmsolutions.ca/
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080416/a7fc43f3/attachment.html
More information about the Dev mailing list
