[OpenLayers-Dev] export an openlayer map in SVG
caledo dj_kroket18 at hotmail.com
Thu Aug 7 11:09:34 EDT 2008
Christopher Schmidt-4 wrote:
> On Thu, Aug 07, 2008 at 02:38:33AM -0700, caledo wrote:
> If you wan a quick and dirty hack, see the osm-layer.html example, which
> uses layer.renderer.root.innerHTML to export an SVG document of the
> current map. This will only work in non-IE browsers, though.
> Regards,
Ok thank you
that's seems interresting.
can I modify the renderer to export vectors from different layers, or event
points from a kml file, or do I have to put my points in a GML file?
Is there a way to export the map also instead of just the vectors?
View this message in context: http://www.nabble.com/export-an-openlayer-map-in-SVG-tp18867044p18872681.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
