[OpenLayers-Dev] Virtual Earth 5+
Erik Uzureau euzuro at gmail.com
Thu Aug 21 15:01:15 EDT 2008
FYI: Virtual Earth support has been updated in OL trunk (up through
VE6.1) and will be available in the upcoming 2.7 release of
OpenLayers.
See: http://trac.openlayers.org/ticket/1540 for more information
On Wed, Jan 30, 2008 at 3:45 PM, Christopher Schmidt
<crschmidt at metacarta.com> wrote:
> On Wed, Jan 30, 2008 at 11:30:12AM -0700, Tim Schaub wrote:
>> Hello-
>> Paul Huey wrote:
>> > All,
>> > Virtual Earth 5+ is fixed (tested in 5 and 6)..
>> Are you referring to an OpenLayers issue?  I only see ticket #373 [1]
>> related to VirtualEarth.
> It's been discussed a couple times on the mailing list: essentially, we
> only support up to v3 of the VE API, because they changed their API in
> later releases.
> To the original poster, please do this:
>> If you are contributing new code, can you open a ticket with a
>> description of the issue you are addressing, and add any code as an
>> attachment to the ticket?  Please see the wiki for information on
>> contributing [2].
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
