[OpenLayers-Dev] How to add multiple measure geometry
Eric Lemoine eric.c2c at gmail.com
Tue Dec 2 12:01:31 EST 2008
Hi. I suppose you have a measure listener registered on the measure
control. The object passed to this listener includes a "geometry"
property referencing the drawn geometry. So, in addition to displaying
your measure result, you can have your listener create a feature from
the geometry and add that feature to a vector layer. Hope this helps,
Eric
2008/12/2, Vidal, Antoni <antoni.vidal at icc.cat>:
> Hello,
> The Measure example i OL 2.7 only add a geometry on the map. If you draw a
> line and then you draw another line or a polygon, the first geometry is
> deleted. I would like to change this behavior and to maintain geometries
> drawn by user.
> Any example or idea will be thankful.
> Thank's in advance
> Antoni Vidal
> Institut Cartogràfic de Catalunya    Tel: +34-93 567 1500 Ext. 3228
> Parc de Montjuïc                             Fax: +34-93 567 1567
> 08038 Barcelona                            http://www.icc.cat
> <http://www.icc.cat/>
> Spain
More information about the Dev mailing list
