[OpenLayers-Dev] baseLayers switcher control (GMapTypeControl-like)
Zac Spitzer zac.spitzer at gmail.com
Thu Dec 4 08:36:37 EST 2008
i'd like to see this in the trunk, it's a ui nice improvement
On Fri, Dec 5, 2008 at 12:15 AM, Pierre GIRAUD <bluecarto at gmail.com> wrote:
> I had no answer so I dove into it myself.
> The first attempt can be seen in a specific sandbox [1].
> It needs more work on the css.
> Is this something we would want into trunk or as an addin ?
> Feedbacks accepted.
> Pierre
> [1] http://dev.openlayers.org/sandbox/camptocamp/maptypepanel/openlayers/examples/mapTypePanel.html
> On Wed, Dec 3, 2008 at 9:54 AM, Pierre GIRAUD <bluecarto at gmail.com> wrote:
>> Hi all,
>> I'm wondering if someone has an example of application or code
>> implementing a control that behaves like the GMapTypeControl, eg
>> adding toogle buttons on the top right of the map to switch between
>> the map baselayers.
>> I found this (very) old ticket.
>> http://trac.openlayers.org/ticket/497
>> Regards,
>> Pierre
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the Dev mailing list
