[OpenLayers-Dev] OpenLS
bartvde at osgis.nl bartvde at osgis.nl
Thu Dec 11 03:38:28 EST 2008
Hi Didier,
I've put up our code in a sandbox. See the following changeset:
http://trac.openlayers.org/changeset/8489
Would be great of you could have a look at it to see if there is overlap.
Also, feel free to edit the sandbox.
I'll try and add some examples and/or tests, but a slight problem is that
I don't know of any free OpenLS service. The service we use is not free.
Best regards,
Bart
Le Mercredi 10 Décembre 2008 11:49, bartvde at osgis.nl a écrit :
> Hi list,
Hi Bart,
> is there any interest in an OpenLS Format for OpenLayers?
Yes for our portal API!
> Have other people developed this as well? Or are we the only ones using
> this :-) ?
We have developped support for OLS and specially focused on Location Utility
Service. It still alpha but reads/writes OLS LUS (XLS compliant based on OLS
1.1 while 1.0 is also supported as an alias of 1.1).
An LUS Layer has also been developed, as well as a control for the Geocode
method (we will be working on the reverse geocode in early 2009).
> XLS Location Utility Service
> If there is any interest I can put up our code in a sandbox.
Why not knowning that there might be some refactoring as the development
relies on a class hierarchy different from OpenLayers (but with the same
"spirit") :
- Geoportal.Format.XLS : XLS read/write
- Geoportal.Layer.OLS : OLS LUS layer
(Geoportal.Layer.OLS.Core.LocationUtilityService)
- OLS : big hierarchy for handling OLS model.
If you are interested, contact me, I'll be pleased to send you this code and
interrested in feedbacks.
> Best regards,
All the best,
didier
> Bart
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Didier RICHARD, chef du pôle technique Géoportail pour l'IGN
Institut Geographique National           tel: +33/0 1.43.98.83.23
2/4 Avenue Pasteur                       fax: +33/0 1.43.98.80.88
F-94165 St-Mande Cedex                e-mail: Didier.Richard at ign.fr
More information about the Dev mailing list
