[OpenLayers-Dev] OLON / context
Lorenzo Becchi lorenzo at ominiverdi.com
Wed Feb 6 06:43:20 EST 2008
> Though I originally suggested that Lorenzo use OLON as an intermediate
> structure for the WMC and OWS Context work, I ended up not using it for
> the WMC work I did.  (This was because I wanted to get the WMC format in
> the trunk before having to completely finish the OLON work.  Apologies
> to Lorenzo.)  The reason it did make sense to use OLON as an
> intermediate structure is that it would be a structure that we could
> agree on (the idea being that wmc.read(doc) should return a regular
> structure that you can rely on).
No problems, Tim.
I think it was a good idea, in any case, to work on OLON. I don't need
yet to have the code on trunk.
In my project we're very close to define the structure of the Map
Context that allows the usage of Overlay, Multiple WMS Layers for each
OL layer, SLDService (geoserver add on) without loosing  standard
compatibility.
I'll let you know soon if you are interested.
ciao
Lorenzo
Tim Schaub wrote:
> Hey-
> Pierre GIRAUD wrote:
>> Hi Tim Schaub and Lorenzo Becchi, and others,
>> I'm really interested in the work you did in the context sandbox and
>> specifically on the OLON format.
>> Can you give clues on what its current state is ?
>> Was it abandoned and replaced by the brand new WMC format ? I thought
>> that this would be used for an history control but it doesn't seem to
>> be.
> The context stuff is pretty solid.  I stopped working on it shortly
> after the foss4g sprint, but I think it has good potential.
> The idea is that any instance of an OL class is serializable if the
> arguments to it's constructor are serializable.  Arguments are
> serializable if they are 1) objects that can be represented as json (no
> circular references) or 2) instances of an OL class that meet the
> condition in the first sentence.
> The serialize/deserialize code is in place.  You can call the static
> OpenLayers.Class.serialize and OpenLayers.Class.deserialize methods on
> any object.  If a prototype has a serializable property (see the
> HTTPRequest layer or others), then instances of a parent class or
> subclass will be serialized as OLON (OpenLayers Object Notation).
> The work left to be done is to 1) go around the library adding
> serializable properties to prototypes (there is a bit of magic with
> inheritance of this property that deserves documentation), and 2) give
> the write method of OpenLayers.Format.OLON a filter option so you can
> specify what you want serialized.
>> Would it be a good start point to build an application level context ?
> Yeah, I think so.
> I'm happy to discuss more on IRC.
> Tim
>> Regards,
>> Pierre
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
>> !DSPAM:4033,47a8842e169801015089218!
> Dev mailing list
More information about the Dev mailing list
