[OpenLayers-Dev] easing js error
Erik Uzureau euzuro at gmail.com
Mon Feb 11 14:24:19 EST 2008
...is there a fix for this in trunk?
erik
On Feb 11, 2008 8:00 AM, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Mon, Feb 11, 2008 at 10:43:10AM +0100, Bart van den Eijnden (OSGIS) wrote:
> > Hi list,
> > using trunk I sometimes run into the following js error:
> Presumably this happens anytime you pan the map a small distance, and
> presumably you have a custom singlefile build of OpenLayers; If so, the
> problem is that OpenLayers.Map does not at the moment declare all of its
> dependancies correctly. You need the OpenLayers.Tween class in your
> build.
> -- Chris
> > OpenLayers.Easing has no properties
> > panTo(lon=146666.6666666667,lat=453333.3333333333 lon=146666.6666666667
> > lat=453333.3333333333)OpenLayers.js (line 508)
> > updateMapToRect()OpenLayers.js (line 409)
> > baseLayerDraw(click clientX=0, clientY=0)OpenLayers.js (line 403)
> > callback("click", [click clientX=0, clientY=0])OpenLayers.js (line 466)
> > clearTimer(click clientX=0, clientY=0)OpenLayers.js (line 659)
> > bind()OpenLayers.js (line 65)
> > [Break on this error] var
> > centerPx=this.getViewPortPxFromLonLat(this.getCenter());var
> > newCenterPx=cent...
> > Best regards,
> > Bart
> > OSGIS, Open Source GIS
> > http://www.osgis.nl
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> Christopher Schmidt
> MetaCarta
> Dev mailing list
More information about the Dev mailing list
