[OpenLayers-Dev] Fwd: [OpenLayers-Commits] r6230 - trunk/openlayers/lib/OpenLayers
Erik Uzureau euzuro at gmail.com
Tue Feb 12 13:10:50 EST 2008
reasonable. i see the logic in but do not like the idea of a
flag to say dont destroy me (and i imagine you dont like
it either :-) so yes, i think the best course of action is just
if (control != null) control.destroy();
oh, i just had a thought. another solution to this would be
make two addControl functions. one would be the public
api and the other would be an internal one. so when you
call
map.addControl( new OL.Control.Navigation());
then the map would know that it is in charge of destroying the
control on map destroy.
but then something like
this.fooControl = new Control();
this.map._addControl(this.fooControl);
... the map would know that fooControl is *not* under its domain.
in the short term, i think the simple if (null) solution is sufficient, but
it might be worth considering the latter... maybe when we do that
fabled memory review
erik
On Feb 12, 2008 11:29 AM, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Tue, Feb 12, 2008 at 10:51:04AM -0600, Erik Uzureau wrote:
> > i dont know what the specific case is here, but i know the following
> > rule tends to work in 99% of cases:
> > if you create it, you destroy it. if you register it, you unregister it.
> The problem is that with controls, the map attempts to destroy them all,
> even though it creates relatively few of them. Without a flag to say
> 'Don't destroy me' (or a more invasive destruction procedure documented
> for all OpenLayers apps), there's no way to prevent duplicate
> destruction.
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
