[OpenLayers-Dev] Cannot set Feature popupClass.
Leandro R learonco at gmail.com
Mon Feb 25 13:02:44 EST 2008
Hi
Thanks for your quick answer, but I had already tried that and did not work.
What else could be?
Thanks
2008/2/25, Erik Uzureau <euzuro at gmail.com>:
> I think the problem here is that you are specifying the class in
> quotes as a string.
> It should just be:
> > feature = new OpenLayers.Feature(layer, new OpenLayers.LonLat(lng,lat),
> > {popupClass:OpenLayers.Popup});
> ---e
> 2008/2/25 Leandro R <learonco at gmail.com>:
> > Hello all !!!
> > I need to change the popup class of a Feature object. I've tried to do
> it as
> > the following, but it has not worked.
> > {popupClass:'OpenLayers.Popup'});
> > I don't want to change that from the file Feature.js.
> > Can anyone help me?
> > Thanks
> > Leandro
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080225/6d961791/attachment.html
More information about the Dev mailing list
