[OpenLayers-Dev] RFC: Migrating OpenLayers SVN + Trac to OSGeo infrastructure
Eric Lemoine eric.c2c at gmail.com
Mon Jan 14 01:45:28 EST 2008
+1. I think it's good to start moving the OL infrastructure to OSGeo.
For the URLs I'd favor the regular OSGeo URLs.
2008/1/13, Cameron Shorter <cameron.shorter at gmail.com>:
> +1
> This is a positive long term move.
> It should ease the integration between projects they are sharing the
> same hosting resources and share the workload.
> Paul Spencer wrote:
> > Chris,
> > I think this is a good move to make for the project, and for OSGeo as
> > well.
> > I don't have any particular feeling about the structure of URLs and
> > would be fine with either structure.
> > While I'm not involved personally in SAC, I would like to help and I
> > can ask Shawn Barnes to help out with any migration support that you
> > need.
> > Cheers
> > Paul
> > On 13-Jan-08, at 7:03 AM, Christopher Schmidt wrote:
> >> OpenLayers is currently (graciously) hosted by MetaCarta. This has
> >> worked out quite well so far, but using MetaCarta hosting has meant
> >> we've had to 'roll our own' system for authentication -- and as many
> >> people know, this particular system is rather hacky: an email to the
> >> PSC
> >> list to generate a new username, which requires manual intervention.
> >> Part of the reason that I've never improved upon this system is that
> >> I've always felt that it would be better to invest in moving to OSGeo
> >> infrastructure. For a while, this was difficult, but recently, OSGeo
> >> has
> >> found some solutiosn which make this technically possible.
> >> I'd like to suggest that we move to OSGeo infrastructure for hosting
> >> Trac and the Wiki as soon as possible. I'm less sure on the website
> >> and
> >> mailing lists.
> >> Benefits of moving svn + wiki:
> >> * Users can create their own userid -- or use their existing osgeo
> >>   userid -- to login to either.
> >> * Users creating tickets in trac will automatically get email
> >> notification
> >>   on updates of their tickets.
> >> * It will be possible to register oneself as a "CC" on a bug without
> >>   exposing an email address to the public web.
> >> * Shared administrative resources with OSGeo -- which means that it's
> >>   not just me who can update the server, but instead the set of people
> >>   who maintain the OSGeo servers
> >> * Shared OSGeo backup infrastructure. Currently, we're backing up
> >>   OpenLayers internally to MetaCarta, and exporting data to OSGeo:
> >>   moving to OSGeo infrastructure allows for the bcakups to be
> >>   maintained by the foundation.
> >> The strongest one to me is that users will be able to create their own
> >> accounts via an automated process - no humans involved. I think this
> >> is
> >> very important.
> >> I have a couple of questions which I don't personally have an answer
> >> to
> >> yet:
> >> Currently, all OSGeo svn, trac, etc. live under URLs like
> >> http://trac.osgeo.org/gdal/ , http://svn.osgeo.org/gdal/ . I do not
> >> know
> >> if it is possible to configure svn.openlayers.org to point directly to
> >> the OSGeo server, or if it would be preferred for administrative
> >> purposes to have it at svn.osgeo.org/openlayers/ . Obviously, even if
> >> it's trivial in an administrative way, it would be more in line with
> >> the
> >> rest of the foundation-hosted projects to have the URL be
> >> svn.osgeo.org/openlayers/ . Assuming that there is sufficiently good
> >> infrastructure setup to allow for users to migrate from one to the
> >> other, would it make sense to make the primary OpenLayers SVN URL be
> >> the
> >> osgeo.org/ form?
> >> Same question applies to trac.
> >> I view these aspects of the project as 'internal' -- where SVN lives
> >> doesn't matter much, so long as it's correctly linked everywhere --
> >> and
> >> would be in support of moving into the osgeo.org namespace for svn and
> >> trac, with appropriate redirects.
> >> A similar question applies to mailing lists. Currently, these lists
> >> are
> >> dev at openlayers.org and users at openlayers.org. Moving to OSGeo
> >> infrastructure would probably mean moving these to
> >> openlayers-users at lists.osgeo.org and openlayers-dev at lists.osgeo.org
> >> (and
> >> openlayers-trac and openlayers-commits.) Would it make sense to move
> >> these, with proper redirects to lists.osgeo.org for both the email
> >> addresses and the archives?
> >> Speaking as (essentially) the sole maintainer of the machine that
> >> openlayers.org is hosted on, I'd like to move off whatever we can to
> >> OSGeo infrastructure. As you can see here, one important piece of the
> >> infrastructure piece is left aside, and that's the sandboxes, website,
> >> etc. I think the important aspect of those changes is related to the
> >> regular 'svn up' and rebuilding that happens. In the past, we've
> >> discovered that doing these in post-commit hooks is bad, because it
> >> takes too long to commit (which would be een more true now with the
> >> NaturalDocs stuff). However, I think that we can devise a technical
> >> solution -- using a post-commit hook to write a revision number, and a
> >> cronjob to check whether changes have been made and rebuild if so. I
> >> think this would allow us to move to OSGeo infrastructure for the
> >> website as well, though there would obviously need to be some
> >> technical
> >> discussions for what we could do as far as doc regeneration, etc.
> >> goes.
> >> This is not a motion yet: its a request for comments. I'm interested
> >> in
> >> moving for a number of reasons, both technical and social. Although
> >> there are other people at MetaCarta with 'the keys' to the servers,
> >> I'd
> >> like to move that out to the foundation -- and I see that we get a
> >> fair
> >> amount of benefit from that. I'm hopeful that others agree, and we can
> >> discuss the best way to move forward with the goal of making the
> >> process
> >> smooth.
> >> Feedback, comments, suggestions, concerns are welcome.
> >> (Note that at the moment, I'm not looking for technical advice on the
> >> way to set up redirects or anything like that: we can address that
> >> after
> >> we address whether, and how, we *want* to move first.)
> >> Regards,
> >> Christopher Schmidt
> >> MetaCarta
> >> _______________________________________________
> >> Dev mailing list
> >> Dev at openlayers.org
> >> http://openlayers.org/mailman/listinfo/dev
> > |Paul Spencer                          pspencer at dmsolutions.ca    |
> > |Chief Technology Officer                                         |
> > |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
> > Dev mailing list
> Cameron Shorter
> Geospatial Systems Architect
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Commercial Support for Geospatial Open Source Solutions
> http://www.lisasoft.com/LISAsoft/SupportedProducts.html
> Dev mailing list
More information about the Dev mailing list
