[OpenLayers-Dev] [OpenLayers-Trac] [OpenLayers] #1260:
SelectFeature and OpenLayers.Feature.Vector.style["select"]
Andreas Hocevar
andreas.hocevar at gmail.com
Sat Jan 19 08:53:42 EST 2008
On Jan 17, 2008 3:01 PM, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Thu, Jan 17, 2008 at 02:49:06PM +0100, Andreas Hocevar wrote:
> > I was thinking about other classes that also draw features, like
> > Control.ModifyFeature. Many of them currently use layer.drawFeature. In
> > the future, they could all use renderer.drawFeature, and just pass the
> > renderIntent.
> Controls should not talk to Renderers. That's breaking an abstraction
> barrier that I'm very much against breaking. Everything that the
> controls do should go through the layer, I think.
If that is the case, we just do the whole thing on layer.drawFeature
instead of renderer.drawFeature.
> It's possible that this is not really true, and that the Renderer base
> class -- accessible via layer.renderer -- is enough of an 'abstraction
> barrier' that it can be treated as a sane abstraction level. I'm not
> convinced of that, and until we make a concious decision otherwise, I
> would encourage all Renderer functions to be used only within the Layer.
> > In that case, we could probably avoid code duplication
> > when doing fallback checks in renderer.drawFeature instead of every
> > other class that needs to draw features.
> That's fine -- we can still do that check at the layer.drawFeature level
> though, no?
Yes, that would be no problem. I'm in favour of that.
Regards,
Andreas.
More information about the Dev
