[OpenLayers-Dev] Problem with custom select and modify controls binding to same onModification event
Mark K. Zanfardino mzanfardino at gmail.com
Thu Jul 17 17:01:04 EDT 2008
Arnd,
Your suggestion and the link to the modified ModifyFeature.js did the trick!
Thanks a ton!
Mark
Arnd Wippermann wrote:
> Hi,
> have a look at this threat at the reply from Oscar.
> http://www.nabble.com/Re%3A--OpenLayers-Trac---OpenLayers---1483%3A-ModifyFeature-control-makes-SelectFeature-control-to-modify-features-to17863300.html#a17863300
> Arnd Wippermann
> Mark K. Zanfardino wrote:
>> My apologies if this is a duplicate message.  I posted a similar email
>> before I'd joined the devel mail list and can't confirm if it was sent
>> to the list or not.
>> NOTE: OpenLayers 2.6 - I am using the selection control and the modify
>> control on the same map. I have written custom behaviors for each of
>> these two controls.  I'm finding that the selection control calls the
>> onModificationX events which are registered to the modify control and
>> not the selection control.  With console.log I can observe that when I
>> choose the select tool and select a given polygon the onModificationX
>> functions are called.  If I omit the modification tool altogether select
>> calls the appropriate onSelect event.
>> This behavior can be viewed at
>> http://crschmidt.net/mapping/wpserverdemo/.  Simply draw a polygon,
>> choose the select tool then select the newly drawn polygon.  You will
>> note that the modify handles will be available and that you can modify
>> the polygon.  This is the same behavior as that of the modify tool.
>> Mark K. Zanfardino
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
