[OpenLayers-Dev] PNG - AGG image, opacity and IE7
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Jul 18 03:20:18 EDT 2008
I have seen this as well. It happens whenever you set the "alpha" value
in IE7.
It even happens if the value is set to 1.0, but a fix in OpenLayers 2.6
removes
the "alpha" value if the opacity value is greater than 1.0.
(OpenLayers.Util.modifyDOMElement line 191).
I'm fairly sure its an IE bug.
Regards, Kenneth Skovhede, GEOGRAF A/S
Guillaume Sueur skrev:
> no, mapserver, but it's a typical client problem.
> when the polygon is filled, it looks quite ok, because only the outline
> border is wrong, but with lines and labels, whaouh, so crap !
> when opacity is 1 or format is standard PNG, the problem doesn't show up.
> Guillaume
> Zac Spitzer a écrit :
>> was this using mapguide? I have seen similiar problems
>> On Fri, Jul 18, 2008 at 12:11 AM, Guillaume Sueur
>> <guillaume.sueur at neogeo-online.net> wrote:
>>> Hi devs,
>>> When displaying a WMS layer (AGG image) with some transparency on IE7,
>>> it shows ugly grey pixels surrounding the borders. I guess it comes from
>>> a mishandling of the antialiased pixels from AGG. Any trick to hold that ?
>>> Thanks
>>> Guillaume
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080718/50d36fc3/attachment.html
More information about the Dev mailing list
