[OpenLayers-Dev] Mouse Wheel
Kyle Mulka mulka at umich.edu
Fri Jul 18 06:07:00 EDT 2008
I was using FF3 on Mac. The example link you gave me worked fine though.
I was able to boil down what I was experiencing into a bare minimum
chunk of code. Use your mouse wheel to zoom in and out of this map to
see what I mean:
http://www.kylemulka.com/temp/openlayers/funkywheel.html
Is that behavior expected given the code? I'm not sure why we decided
to use the MouseDefaults control instead of Navigation. I'll have to
ask my partner who wrote it.
-Kyle
On Fri, Jul 18, 2008 at 2:06 AM, Guillaume Sueur
<guillaume.sueur at neogeo-online.net> wrote:
> actually Kyle is not pointing at the same problem. The former discussion
> asked why OL didn't center the map on the position of the mouseWheel, which
> is indeed a bad idea.
> As Chris said in his reply, OL zoomwheel keeps the same point under the
> cursor, just as GoogleMaps does.
> But it looks like Kyle doesn't get this kind of behaviour, which works
> perfectly fine in the examples page
> (http://www.openlayers.org/dev/examples/example-list.html)
> any more hint Kyle (browser version for instance ? )
> Thanks
> Guillaume
> bartvde at osgis.nl a écrit :
>> It's by design, see:
>> http://www.mail-archive.com/users@openlayers.org/msg03396.html
>> Best regards,
>> Bart
>>> When you use the mouse wheel to zoom in and out, shouldn't the point
>>> under the mouse cursor stay the same? This works as expected with
>>> Google Maps, but fails miserably with OpenLayers. I'm wondering if
>>> this is something that would be easy to fix, assuming the default
>>> behavior is to just zoom from the center of the map instead of from
>>> the mouse position.
>>> Kyle Mulka
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> Dev mailing list
Kyle Mulka
More information about the Dev mailing list
