[OpenLayers-Dev] Open Layers Documentation
Erik Uzureau
euzuro at gmail.com
Mon Mar 3 11:31:06 EST 2008
Unfortuntely, OpenLayers is an underfunded open source project. There
is simply no
resources to maintain professional documentation.
http://dev.openlayers.org/apidocs, however, might help
erik
2008/3/3 Nader Chouman - WSN <naderc at wsn.net>:
> Hi list,
> I am a software developer with a solution integrating company called "Wall
> Street Networks" and I recently started working with OL as I found it can be
> very useful in terms of some projects we are currently working on. However,
> I couldn't get much out of the documentation provided by the site. I would
> appreciate some references to related resources and to a well defined
> Programmers API with explanation or examples of the parameters, properties
> and methods exposed by different classes in OL. I appreciate any help I can
> get.
> Thank you,
> NADER CHOUMAN
> Software Developer
> 110 Wall Street, 15th Floor
> New York, NY 10005
> Tel 212.635.0100 x245
> Fax 212.635.0030
> naderc at wsn.net
> www.wsn.net
> The information transmitted is intended only for the person or entity to
> which it is addressed and may contain confidential and/or privileged
> material. Any review, retransmission, dissemination or other use of, or
> taking of any action in reliance upon, this information by persons or
> entities other than the intended recipient is prohibited. If you received
> this in error, please contact the sender and delete the material from all
> computers. Thank You.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
