[OpenLayers-Dev] Xlink sous IE
fgenin fgenin at bcisa.com
Thu Mar 6 04:39:27 EST 2008
Yes , I use the SVG adobe viewer to display SVG in IE. And the SVG image is
defined in this documentation
http://www.w3.org/TR/SVG/struct.html#ImageElement
Thanks
Fabrice
Pierre GIRAUD wrote:
> What do you mean by "I'm using an SVG image" ? Where is the SVG image
> added to your code ?
> You must be aware that IE doesn't support SVG and for microsoft
> browsers the chosen OpenLayers vector renderer is the VML one.
> Regards
> Pierre
> On Thu, Mar 6, 2008 at 10:00 AM, fgenin <fgenin at bcisa.com> wrote:
>>  Hy Tim,
>>  I'm using an SVG image with an Xlink href like that : <image
>>  xlink:href="arrow.png">.
>>  For that, I added the attribute
>>  xmlns:xlink=http://www.w3.org/1999/xlink to the SVG root.
>>  It's well working in firefox 2.x but not in IE7.
>>  Any ideas?
>>  Thanks,
>>  Fabrice
>>  Tim Schaub wrote:
>>  > Hey-
>>  > fgenin wrote:
>>  >> Hy guys,
>>  >> do you know if Xlink is compatible with IE7 in order to use the
>>  >> xlink:href
>>  >> tags?
>>  > I think the more relevant question is: who cares?
>>  > (discussion on that question from 2002
>>  > http://www.xml.com/pub/a/2002/03/13/xlink.html)
>>  > More seriously, can you give a bit more context to your question?
>>  > Tim
>>  >> Thanks for your help!
>>  >> Fabrice
>>  >> GIS developper
>>  > _______________________________________________
>>  > Dev mailing list
>>  > Dev at openlayers.org
>>  > http://openlayers.org/mailman/listinfo/dev
>>  View this message in context:
>> http://www.nabble.com/Xlink-sous-IE-tp15853289p15869137.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
> Dev mailing list
View this message in context: http://www.nabble.com/Xlink-sous-IE-tp15853289p15869704.html
More information about the Dev mailing list
