[OpenLayers-Dev] Fwd: Web-based Configuration using Mapbuilder for GSoC 2008
Tharindu Mathew mccloud35 at gmail.com
Fri Mar 14 01:30:47 EDT 2008
---------- Forwarded message ----------
Date: Fri, Mar 14, 2008 at 10:44 AM
Subject: Re: [OpenLayers-Dev] Web-based Configuration using Mapbuilder for
GSoC 2008
To: Cameron Shorter <cameron.shorter at gmail.com>
I already have looked into javascript. I'll look into XSL. Are other XML
stuff like XPath or XQuery used?
I will look into the links you gave me. Thanks for the assistance.
On Fri, Mar 14, 2008 at 3:48 AM, Cameron Shorter <cameron.shorter at gmail.com>
wrote:
> Hello Mathew,
> Nice to meet you and great to hear this project is of interest.
> In my opinion, understanding of good programming practices and design is
> more important than specific language issues which can be learned as you
> code. The structure of Java is similar to Javascript which will give you
> a good start. Probably the best way to start is to read some tutorials
> and have a look at the code in existing applications. (Things like
> inheritance are done differently in javascript).
> Understanding XSL will be beneficial for the Mapbuilder parts of this
> project.
> http://trac.openlayers.org/wiki/Documentation
> http://docs.codehaus.org/display/MAP/Developers+Guide
> http://docs.codehaus.org/display/MAP/Tutorials
> (Plenty of pages here, I don't suggest you read them all yet)
> Tharindu Mathew wrote:
> > Hi,
> > I'm interested in this project and is looking for an  oppurtunity to
> > learn the technologies associated with this project. But my experience
> > with JavaScript is limited. I have manly used Java as my language and
> > worked with XML web services, spring framework, etc in Java.
> > Will my limited JavaScript experience be a problem in this project? If
> > not, how may I gather more knowledge for this project?
> > Regards,
> > Tharindu
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> Cameron Shorter
> Geospatial Systems Architect
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Commercial Support for Geospatial Open Source Solutions
> http://www.lisasoft.com/LISAsoft/SupportedProducts.html
Regards,
Tharindu
Regards,
Tharindu
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080314/0be92638/attachment.html
More information about the Dev mailing list
