[OpenLayers-Dev] Summer of Code: Why two 'web-based configuration' ideas?
Cameron Shorter cameron.shorter at gmail.com
Sun Mar 16 06:40:30 EDT 2008
PS. I suggest discussing this during the Mapbuilder team meeting in 1.5
days at:
Place    Time
Sydney    Tue 06:00
Amsterdam (Central European Time)    Mon 20:00
New York (Eastern Standard Time)    Mon 14:00
Los Angeles (Western Standard Time)    Mon 11:00
Greenwich Mean Time    Mon 19:00
http://www.timeanddate.com/worldclock/meetingdetails.html?hour=19&min=0&sec=0&p1=240&p2=16&p3=179&p4=137
Cameron Shorter wrote:
> Chris,
> Your comments are valid and it would probably help to have an IRC
> discussion to discuss this in real time. (I note that I don't have a
> detailed understanding of Lorenzo's WMC builder code).
> In a nutshell, I think the key difference between the Mapbuilder
> approach and that of Openlayers is the use of XSL for service chaining
> and keeping models in XML instead of JS:
> Mapbuilder:
> * Stores OWS Context as an XML file.
> * Uses XSL to convert various outputs (GetCapabilities response,
> Catalog search response, etc) to OWS Context.
> * Exports from OWS Context to other formats (like GML, WMC, KML, ...)
> using XSL. (not complete)
> Openlayers:
> As I understand it, Lorenzo's code converts WMC to JS objects, then
> does manipulation of those JS objects.
> Christopher Schmidt wrote:
>> Cameron, Steven, Roald,
>> Before the MapBuilder meeting a couple weeks ago, there was an
>> OpenLayers Summer of Code idea titled "Web-based Configuration". I just
>> looked at the SoC page [1], and realized there are now *two * web-based
>> configuration ideas on the page, without a significant explanation as to
>> why there are two seperate ideas.
>> It seems to me like some portion of the "web-based configuration" code
>> that would be created by such a project should not be specific to
>> MapBuilder. Additionally, I think that currently, there are two ideas
>> that are not sufficiently different in their goals for a student to
>> understand why they would choose one over the other.
>> I'm happy if you want to make the primary frontend for such an
>> application be MapBuilder, but if that's the case, then it should be an
>> extension of the code that would be written on the backend.
>> Help me understand what's going on here? Why are the first two tasks on
>> the list not integrated into one idea?
>> [1] http://trac.openlayers.org/wiki/SummerOfCode
>> Thanks in advance,
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source Solutions
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
More information about the Dev mailing list
