[OpenLayers-Dev] Bug in rendering features with cluster strategy
Alexandre Dube adube at mapgears.com
Fri Nov 7 14:03:34 EST 2008
I tried this small patch but unfortunately the problem persist. Is there
a new patch for this issue ( feature stays on screen when zooming with
mouse over it with cluster strategy ) ?
If not, I would like to disable the wheel zoom. How can I do that ?
Alexandre
Tim Schaub wrote:
> Hey-
> Eric Lemoine wrote:
>> Yes. Especially since drawFeature is often called from addFeatures,
>> where we're assured that the feature is in the layer. So, instead, we
>> may want to change the select feature control so that it calls
>> drawFeature only if, in the case of selection, the feature is in the
>> "features" array, and in the case of unselection, the feature is in
>> the "selectedFeatures" array. What do you think? Eric
> The problem is in the Feature handler.  We destroy features, but
> references to them are still truthy.  Since the destroy code sets the
> layer property to null, one check of an undestroyed feature is to check
> feature.layer.
> See http://trac.openlayers.org/attachment/ticket/1806/destroyed.patch
>> 2008/11/4, Tim Schaub <tschaub at opengeo.org>:
>>> Hey-
>>> Ivan Grcic wrote:
>>>> OK... i found it..inside Layer.Vector...now the question is: should i
>>>> put something like this:
>>>> if (OpenLayers.Util.indexOf(this.features, feature) != -1){
>>>> inside drawFeature: function(feature, style) {
>>> Nope.  Making drawFeature that safe at the expense of iterating through
>>> every feature with every draw is a mistake.
>>>> or inside every other function inside Layer.Vector that uses
>>>> drawFeature function?
>>>> When I put it here:
>>>> -->	if (OpenLayers.Util.indexOf(this.features, feature) != -1){
>>>> it works pretty fine for me :) Eric?
>>>> On Mon, Nov 3, 2008 at 9:53 AM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
>>>>> Yup, its not Cluster Strategy...
>>>>> http://trac.openlayers.org/ticket/1806#comment:2
>>>>> On Mon, Nov 3, 2008 at 9:11 AM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>>>>>> Hi.
>>>>>> Yes, this looks like a bug in OpenLayers.
>>>>>> I'm under the impression that this isn't a bug in the cluster strategy
>>>>>> but either in Layer.Vector or in Control.SelectFeature. Indeed, I
>>>>>> think SelectFeature calls layer.drawFeature on feature
>>>>>> selection/unselection without checking whether the feature is in the
>>>>>> layer. And i'm saying this may be a bug in Layer.Vector because it may
>>>>>> be that drawFeature should be responsible for checking whether the
>>>>>> feature is in the layer before actually drawing it.
>>>>>> This is just coming from the top of my head so i may be wrong, but i'm
>>>>>> feeling this is a good track to follow :)
>>>>>> Eric
>>>>>> 2008/11/2, Ivan Grcic <ivan.grcic at geofoto.hr>:
>>>>>>> Hi list,
>>>>>>> i discovered a bug while developing my OL application, in cluster
>>>>>>> strategy class.
>>>>>>> Bug occurs when you hover over one feature that represent a cluster
>>>>>>> (or externalGraphic or like in cluster example - vector circle
>>>>>>> http://openlayers.org/dev/examples/strategy-cluster.html)
>>>>>>> When you zoom in/out while that feature-cluster is selected (by
>>>>>>> quickly double-clicking or easier using scroll on ur mouse), on next
>>>>>>> zoom that cluster is rendered (stays on screen) together with newly
>>>>>>> created clusters! And clearly it shouldnt be there. The old
>>>>>>> ("phantom") cluster is not selectable, as he doesnt exist on the new
>>>>>>> zoom level..he just stays there on screen...annoying me :)
>>>>>>> As you zoom in again and again, phantom clusters always render, always
>>>>>>> at the same position in the map div...
>>>>>>> Please confirm that this is a bug, im going crazy here with this one :|
>>>>>>> Ivan Grcic
>>>>>>> _______________________________________________
>>>>>>> Dev mailing list
>>>>>>> Dev at openlayers.org
>>>>>>> http://openlayers.org/mailman/listinfo/dev
>>>>> Ivan Grcic
>>> Tim Schaub
>>> OpenGeo - http://opengeo.org
>>> Expert service straight from the developers.
>>> Dev mailing list
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev mailing list
