[OpenLayers-Dev] popup closebox issue
Eric Lemoine eric.c2c at gmail.com
Tue Nov 11 06:19:58 EST 2008
I do see the bug with Safari 3.0.3 on w$. Eric
2008/11/10, Jerome Freyre <jerome.freyre at hispeed.ch>:
> I must sorry me too...
> I did not read english very good and I misunderstood you...
> It's really strange...
> Hope it is also working on Eric Lemoine's computer...
> Sincerly,
> Jérome
> euzuro wrote:
>> Sorry, I don't explain myself correctly... I just tried it again and the
>> popup close box IS there.
>> The first time I tried this (last week?) I opened the same example and I
>> swear it wasn't there.
>> again, sorry for the confusion.
>> erik
>> On Mon, Nov 10, 2008 at 9:47 AM, Jerome Freyre
>>> Maybe can you try to update your safari and check the example again?
>>> Personnaly, I use Windows Vista...
>>> euzuro wrote:
>>> > This is really wierd. I just checked again and it's there.
>>> > again, win xp safari 3.0.4
>>> > I have no explanation for this, apologies.
>>> > On Mon, Nov 10, 2008 at 2:31 AM, Jerome Freyre
>>> >> Hi Eric and euzuro,
>>> >> I tried the example :
>>> http://openlayers.org/dev/examples/popupMatrix.html
>>> >> On my pc with safari 3.1.2 and the closebox is correctly working and
>>> >> rendered...
>>> >> Wich version of safari are you using?
>>> >> Jerome Freyre wrote:
>>> >> > Hi Eric,
>>> >> > There is no problem with the popup closebox on Safari with a mac...
>>> >> > I'll try this week end on my pc with safari...
>>> >> > Eric Lemoine-3 wrote:
>>> >> >> Hello
>>> >> >> I noticed that the popup closebox is not rendered on Safari (Safari
>>> >> >> 3.0.3 on Windows). Has anyone else experienced that? Is the problem
>>> >> >> existing on Safari on Mac as well?
>>> >> >> Thanks,
>>> >> >> Eric
>>> >> >> _______________________________________________
>>> >> >> Dev mailing list
>>> >> >> Dev at openlayers.org
>>> >> >> http://openlayers.org/mailman/listinfo/dev
>>> >> View this message in context:
>>> >> http://www.nabble.com/popup-closebox-issue-tp20378034p20416102.html
>>> >> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>>> >> Dev mailing list
>>> > Dev mailing list
>>> http://www.nabble.com/popup-closebox-issue-tp20378034p20422410.html
>>> Dev mailing list
>> Dev mailing list
> http://www.nabble.com/popup-closebox-issue-tp20378034p20422562.html
> Dev mailing list
More information about the Dev mailing list
