[OpenLayers-Dev] Simple Styling Problem
    Tim Schaub
    tschaub at opengeo.org
    Mon Nov 24 13:46:47 EST 2008
Hey-
Toby Rainthorpe wrote:
> Given the simple test below, does anyone know how I would style the
> test_territory polygon? Or for that matter the whole of the
> vector_layer?
If you haven't already, read through the StyleMap example:
http://openlayers.org/dev/examples/stylemap.html
This gives you a bit more functionality than you need for styling a
single polygon, but it is good to have an understanding of the parts if
you are going to be building something more complex.
Tim
> Thanks for your help,
> Toby
> <html xmlns="http://www.w3.org/1999/xhtml">
>    <head>
>      <link rel="stylesheet" href="../theme/default/style.css"
> type="text/css" />
>      <link rel="stylesheet" href="style.css" type="text/css" />
>      <script src="../lib/OpenLayers.js"></script>
>      <script type="text/javascript">
>      var lon = 0.30271;
>      var lat = 53.29408;
>          var zoom = 8;
>          var map, layer;
>          function init(){
>              map = new OpenLayers.Map( 'map' );
>              layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>                      "http://labs.metacarta.com/wms/vmap0",
>                      {layers: 'basic'} );
>              map.addLayer(layer);
>              map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
>              var test_territory = {"type":"Polygon","coordinates":
> [[[0.30271,53.29408],[0.32185,53.27152],[0.23484,53.19422],
> [0.19443,53.21331],[0.16971,53.21241],[0.08345,53.23488],
> [0.02083,53.24781],[-0.01269,53.17102],[-0.13717,53.14185],
> [-0.15075,53.12439],[-0.13071,53.02398],[-0.22929,53.00390],
> [-0.33850,53.06091],[-0.40868,53.05562],[-0.45224,53.05795],
> [-0.48515,53.12857],[-0.52103,53.14277],[-0.54183,53.19215],
> [-0.49520,53.22299],[-0.48566,53.22575],[-0.51875,53.22722],
> [-0.53484,53.22819],[-0.53926,53.22850],[-0.53759,53.23366],
> [-0.55354,53.25197],[-0.57064,53.23427],[-0.56796,53.23333],
> [-0.54251,53.22764],[-0.54796,53.21912],[-0.55416,53.20214],
> [-0.56246,53.19333],[-0.57082,53.17395],[-0.67832,53.10239],
> [-0.69929,53.07564],[-0.71693,53.11059],[-0.67402,53.21872],
> [-0.66818,53.25521],[-0.77575,53.24668],[-0.76478,53.26913],
> [-0.75146,53.32024],[-0.56708,53.35294],[-0.54906,53.42575],
> [-0.46125,53.42901],[-0.45928,53.43568],[-0.49191,53.49760],
> [-0.41390,53.55006],[-0.31045,53.52675],[-0.21935,53.52730],
> [-0.21503,53.50638],[-0.20327,53.46674],[-0.12254,53.45489],
> [0.02643,53.46201],[0.08385,53.49654],[0.22836,53.40840],
> [0.26803,53.34254],[0.30271,53.29408]],[[-0.40406,53.32102],
> [-0.41035,53.29527],[-0.42949,53.26455],[-0.36920,53.22594],
> [-0.37631,53.20236],[-0.31336,53.18250],[-0.28899,53.17916],
> [-0.25398,53.23297],[-0.30694,53.33457],[-0.40406,53.32102]]]};
>             var geojson_format = new OpenLayers.Format.GeoJSON();
>             var vector_layer = new OpenLayers.Layer.Vector();
>             map.addLayer(vector_layer);
> vector_layer.addFeatures(geojson_format.read(test_territory));
>      </script>
>    </head>
>    <body onload="init()">
>      <h1 id="title">GeoJSON Example</h1>
>      <div id="map" class="smallmap"></div>
>    </body>
> </html>
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
