[OpenLayers-Dev] Canvas for Safari?...instead of SVG and iphone?
Garthanos
lancelot at inetnebr.com
Thu Sep 4 12:56:35 EDT 2008
I want to confirm a recent build does indeed detect svg support
correctly in Safari.
I am kind of assuming the vector rendering will be auto
detecting the availability of canvas as a rendering option
when svg and vml are not available?
Christopher Schmidt-4 wrote:
> On Wed, Sep 03, 2008 at 08:55:27AM -0500, Lance Dyas wrote:
>> I am just wondering how close the canvas renderer for safari is to being
>> ready
> I don't know, how much more ready than "Checked into trunk with
> examples, tests, etc." do you want?
>> actually at one point OpenLayers vector rendering via SVG worked in
>> Safari..
>> but Safari is a moving target and it quit doing so ... (I think
>> dynamically added
>> SVG elements fail to render, ones read and parsed from doc directly work)
> Er, SVG works fine in Safari. I've been using it regularly. (And by
> regularly, I mean 'daily'.) Why do you think it fails?
>> And did I hear canvas will work on the iphone?
> Yes, the Canvas renderer in trunk works on the iphone.
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
View this message in context: http://www.nabble.com/Canvas-for-Safari-...instead-of-SVG-and-iphone--tp19289750p19315063.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
