[OpenLayers-Dev] ArcGIS server 9.2 support for OL
mpriour mpriour at kestrelcomputer.com
Thu Sep 11 01:11:52 EDT 2008
Post the configuration options for your map, AGS layer and KaMap layer. Also
if you could attach or share the AGS XML config file, that would be helpful
too
Matt Priour
RajC wrote:
> I am trying to overlay AGS created cache layer over a KaMAP created Cache
> Layer of the same data set.
> However, even after following the tips in this forum, I am unable to get
> them lined up.
> The AGS layer is not lining up at the correct coord position. I have
> generated the AGS cache and set the layer creation with the right extent
> and tile origin.
View this message in context: http://www.nabble.com/ArcGIS-server-9.2-support-for-OL-tp9691195p19427982.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
