[OpenLayers-Dev] GeoExt proposal
Cameron Shorter cameron.shorter at gmail.com
Mon Apr 6 16:34:41 EDT 2009
I've delayed to this thread because I've wanted to consolidate my own
thoughts on this.
OSGeo is valuable in that is provides a "Best of breed" branding to
projects associated with it.
So far, we have protected the brand by requiring projects to prove their
quality through the incubation process.
What I'm not clear about is whether we dilute the OSGeo brand by
allowing projects to associate with OSGeo by other means, like assigning
their copyright to OSGeo. This is something new, and I think should be
discussed in a wider forum. I think that a project wanting to assign
copyright to OSGeo should need to assign themselves to OSGeo Labs first:
http://wiki.osgeo.org/wiki/OSGeo_Labs
Tim Schaub wrote:
> Hey-
> Paul Spencer wrote:
>> I feel this is covered by
>>> "The OpenLayers PSC will ask the GeoExt PSC to provide evidence that
>>> code contributions are free from encumbrances.  Further, the
>>> OpenLayers PSC will provide guidance to the GeoExt PSC if it appears
>>> that GeoExt is in violation of any other criteria of an OSGeo member
>>> project."
>> I *think* you are suggesting that this be done before accepting ...  I'm
>> +1 on accepting the proposal as is, OpenLayers PSC is not accepting the
>> copyright, just accepting a role in ensuring that the project is run in
>> a way that is acceptable to OSGeo.
>> When a project enters incubation, it doesn't have to have complete
>> processes before starting.  You are proposing that we impose more
>> rigorous rules on a project that isn't even trying to enter incubation.
> Exactly.  Nobody is asking OpenLayers to do what OSGeo does during the
> incubation process.
> I really want to limit what we are asking the OpenLayers PSC to take on.
>   Again, nothing is required (legally or otherwise) to assign copyright
> to OSGeo.  This is simply a courtesy.
> I'd like to take up the subject separately with OSGeo - requesting that
> they provide a set of guidelines that projects follow before assigning
> copyright.
> Tim
>> Paul
>> On 30-Mar-09, at 9:56 PM, Cameron Shorter wrote:
>>> I'm answering to this email from an "Incubation Committee" member more
>>> than as an "Open Layers PSC" member.
>>> I applaud GeoExt's embracement of OSGeo principles and assigning of
>>> their license to the OSGeo. This will increase adoption and mitigate the
>>> risk of future legals battles if done right.
>>> However, there is more to be done than just assigning copyright of the
>>> project. You also need to protect the code base from being polluted
>>> intentionally or accidentally with incompatibly licensed code.
>>> OSGeo projects protect themselves by setting up processes for their
>>> committers to follow and sign up to, which include rules for accepting
>>> new code and new members.
>>> I suggest that this proposal is extended to include some of these
>>> processes. (You might be able to cut and paste the Open Layers
>>> processes, or use them outright).
>>> I'll vote positively after this has been addressed.
>>> Tim Schaub wrote:
>>>> Hey-
>>>> So, I'm picking up the GeoExt governance proposal again.
>>>> Please see the links below for a history of the issue [1], [2].
>>>> The executive summary follows: GeoExt is a new project that brings
>>>> OpenLayers functionality to Ext JS widgets and data utilities.  The
>>>> GeoExt PSC would like to assign copyright for the code to OSGeo.  OSGeo
>>>> suggested that out of courtesy, the GeoExt PSC make a proposal to an
>>>> OSGeo member project asking the member project to accept a role in the
>>>> governance of the new project.
>>>> The responsibilities of this role (for the OpenLayers PSC and for the
>>>> GeoExt PSC) are described here:
>>>> http://www.geoext.org/trac/geoext/wiki/governance
>>>> What does this mean for the OpenLayers PSC?
>>>> The OpenLayers PSC will ask the GeoExt PSC to provide evidence that code
>>>> contributions are free from encumbrances.  Further, the OpenLayers PSC
>>>> will provide guidance to the GeoExt PSC if it appears that GeoExt is in
>>>> violation of any other criteria of an OSGeo member project.
>>>> What does this means for the GeoExt PSC?
>>>> The GeoExt PSC will gather signed license agreements from code
>>>> contributors.  It will provide a report (periodically or generated on
>>>> demand) all contributors and status of their CLA.  In addition, the
>>>> GeoExt PSC will continue to govern the project in a way that conforms
>>>> with the guidelines for OSGeo member projects.
>>>> What does this *not* mean?
>>>> The OpenLayers PSC will *not* be responsible for examining the commit
>>>> logs, tracking down code contributors, asking individuals to sign the
>>>> CLA, or any duties that have to do with technical aspects of managing
>>>> the GeoExt project.  The OpenLayers PSC will also *not* vote on issues
>>>> before the GeoExt PSC.
>>>> Why is this happening?
>>>> See the links below for a little history.  Basically, anyone can assign
>>>> copyright to OSGeo.  Frank Warmerdam suggested that the OSGeo would
>>>> probably be happier about having copyright assigned if a current member
>>>> project accepted some role in the governance of the new project (the one
>>>> assigning copyright).  OSGeo doesn't have any real responsibility for
>>>> the non-member projects that assign it copyright.  By extension,
>>>> OpenLayers does not assume any real liability under this agreement (its
>>>> status as a member project is not jeopardized if the terms of the
>>>> agreement are not met).  This is largely a courtesy to the OSGeo.
>>>> So, as a member of the OpenLayers PSC, I'd like to propose that we
>>>> accept this role in the governance of the GeoExt PSC.  I'm happy to
>>>> answer any more specific questions about what this means.
>>>> Thanks for the vote and/or questions.
>>>> Tim
>>>> [1] http://n2.nabble.com/copyright-question-td2088465.html
>>>> [2] http://n2.nabble.com/proposal-for-GeoExt-governance-td2477185.html
>>> Cameron Shorter
>>> Geospatial Systems Architect
>>> Tel: +61 (0)2 8570 5050
>>> Mob: +61 (0)419 142 254
>>> Think Globally, Fix Locally
>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>> http://www.lisasoft.com
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>>    Paul Spencer
>>    Chief Technology Officer
>>    DM Solutions Group Inc
>>    http://research.dmsolutions.ca/
Cameron Shorter
More information about the Dev mailing list
