[OpenLayers-Dev] How do metacarta provide the VPF feed?
Christopher Schmidt crschmidt at metacarta.com
Thu Apr 23 20:37:12 EDT 2009
On Thu, Apr 23, 2009 at 05:01:36PM -0400, Schuyler Erle wrote:
> On Thu, 2009-04-23 at 21:02 +0100, Ian Mayo wrote:
> > Does anybody here know how metacarta produce this WMS layer?  I'm
> > familiar with VPF, but a google search indicates that the GeoServer
> > VPF implementation is a little dodgy - so I presume they're either not
> > using GeoServer or not using the native VPF viewer.
> It's rendered with MapServer, backed by GDAL/OGR and OGDI. I think I
> wrote the map file for it when I was working there, unless my memory is
> seriously distorted.
No serious distortion.
> They've probably tweaked it since.
Not a bit.
> For example, I don't remember if we use ogr2ogr to convert the VPF
> data to Shapefile, or whether it reads the VPF data directly.
Neither :) The data was originally converted (before either of our time,
I believe) using now-defunct binary only ogdi tools.
-- Chris
> SDE
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
