[OpenLayers-Dev] ArcXML support
    David Zwarg
    dzwarg+ol_dev at avencia.com
    Mon Apr 27 13:18:43 EDT 2009
Hello,
The ArcXML implementation is incomplete, yes.  I wrote it to support basic
thematic mapping, and I can add other renderers as folks need them.
Although, it looks like you added a simple renderer below -- probably filing
a patch would be the fastest way to get it in to ArcXML.
It's definitely possibly to send ArcXML directly to ArcIMS, although I would
like to see more of the spec implemented in the format itself first.
-Zwarg
On Mon, Apr 27, 2009 at 9:39 AM, <stegch at web.de> wrote:
> Hello,
> I tried to test ArcXML support for OpenLayers. It's great that ArcXML
> works, but there are many restrictions. For example there's no
> SIMPLERENDERER in ArcXML.js, which could be added very easily:
>   addSimpleRenderer: function(renderElem, renderer) {
>     var keys_simplerenderer = [
>       'gradient', 'hashline', 'rasterfill', 'rastermarker', 'simpleline',
> 'simplemarker',
>       'simplepolygon', 'truetypemarker'
>     var keys_attributes = [
>       'angle', 'anglefield', 'antialiasing', 'boundary',
> 'boundarycaptype', 'boundarycolor',
>       'boundaryjointype', 'boundarytransparency', 'boundarytype',
> 'boundarywidth', 'captype',
>       'character', 'color', 'fillcolor', 'fillinerval',
> 'filltransparency', 'filltype', 'finishcolor',
>       'font', 'fontcolor', 'fontsize', 'fontstyle', 'glowing', 'hotspot',
> 'image', 'interval',
>       'jointype', 'linethickness', 'outline', 'overlap', 'rotatemethod',
> 'shadow', 'size',
>       'startcolor', 'tickthickness', 'transparency', 'type', 'url',
> 'usecentroid', 'width'
>     var symbol = renderer.symbol;
>     for (var i=0, len=keys_simplerenderer.length; i<len; i++) {
>       var key = keys_simplerenderer[i];
>       if(symbol.type == key) {
>         var selem = this.createElementNS("", key.toUpperCase() +
> "SYMBOL");
>         for (var j=0, len=keys_attributes.length; j<len; j++) {
>           var key = keys_attributes[j];
>           renderElem.appendChild(selem);
>           if (symbol[key]) {
>             selem.setAttribute(key, symbol[key]);
> Or is there any possibility to send an ArcXML string directly to ArcIMS?
> Furthermore, I think that there could be a little bug inside
> VALUEMAPLABELRENDERER, because "symbol" is undefined in line 5 60 in
> ArcXML.js. It should be declared as "var symbol = exact.symbol;"
> Thank you for your answer.
> Regards,
> Christian
> Psssst! Schon vom neuen WEB.DE MultiMessenger gehört?
> Der kann`s mit allen: *http://www.produkte.web.de/messenger/?did=3123*<http://www.produkte.web.de/messenger/?did=3123>
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090427/65e1ba36/attachment.html
More information about the Dev
