[OpenLayers-Dev] panzoombar leaks
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Mon Feb 23 11:57:53 EST 2009
Hi Eric,
I haven't checked since I don't know a comparable tool like Drip for
other browsers.
Btw, I've opened up a ticket since I found the cause (the divs are
created before the map has a baselayer, and then again when the
baselayer is added to the map, Drip reports the memory leak already when
the page is loaded once without even auto-refreshing the page):
http://trac.openlayers.org/ticket/1949
Best regards,
Bart
Eric Lemoine wrote:
> Bart, do you observe leaks with every browser?
> Eric
> 2009/2/19, bartvde at osgis.nl <bartvde at osgis.nl>:
>> Hi list,
>> has anybody noticed the PanZoomBar control leaks quite a lot of memory?
>> Try and run:
>> http://openlayers.org/dev/examples/controls.html
>> in Drip with the auto-refresh option, and memory will increase in no time
>> from around 20 Mb to 80 Mb.
>> Any ideas/pointers wrt how to solve this?
>> Best regards,
>> Bart
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
More information about the Dev mailing list
