[OpenLayers-Dev] Load external GML file in OpenLayers
Andreas Hocevar ahocevar at opengeo.org
Wed Feb 25 11:02:02 EST 2009
2009/2/25 Gorka López Rivacoba <gorka.lopez.rivacoba at gmail.com>:
> I have an application an I want to load an external GML file. When I load it
> from an internal file (like ".\file.gml") it's ok, but when I load from an
> external file (like "C:\file.gml") there is an error: in this line:
> C:\DesarrolloTINSA\mfbase\openlayers\lib\OpenLayers\Request\XMLHttpRequest.js:
> this._object.open(sMethod, sUrl, bAsync, sUser, sPassword);
> I don't have any problem with permissions, because it is for internal
> porpouse. Is there any solution to this problem?
Although you think so, the browser sees a security problem here. See
http://en.wikipedia.org/wiki/Same_origin_policy for more details.
Are you planning to go online with your application? If this is
designed to run off disk, you should use corect file urls, like this:
file:///C:/file.gml
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
