[OpenLayers-Dev] IE cluster/protocol error - 'status' is null or not an object
Tim Schaub tschaub at opengeo.org
Thu Jan 8 23:45:53 EST 2009
Hey-
Andreas Hocevar wrote:
> Hi,
> On Wed, Dec 10, 2008 at 12:02 AM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
>> HI, can please somebody confirm this? tnx
> yes, I can confirm this. But unfortunately I have not figured out yet
> what might be causing it.
Is this still a problem after http://trac.openlayers.org/changeset/8581 ?
If so, please send along a ticket number.
Thanks,
Tim
> Can you create a ticket (or point me to it if there is already one
> that I missed)?
> Thanks!
> Andreas.
>> On Thu, Dec 4, 2008 at 11:01 AM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
>>> Hi,
>>> aaargh another IE(7) issue :(  It occurs on IE when youre using
>>> cluster strategy.
>>> Its easily reproducible:
>>> 1) open http://openlayers.org/dev/examples/strategy-cluster.html ->
>>> everything shows up ok
>>> 2) hit refresh ur enter the page again (hit enter on url address) -
>>> cluster dont appear and attached error shows up ;(
>>> 3) you can reload page again and again and again.....move/zoom map
>>> hoping the features will load...... but nothing happens until you dont
>>> clear ur IE cache and load page again!
>>> I dont know if its a problem about protocol or cluster....
>>> Please do you know how can this be quickly solved?
>>> Thank you!
>>> Regards,
>>> Ivan Grcic
>> Ivan Grcic
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev mailing list
