[OpenLayers-Dev] destroy
Erik Uzureau euzuro at gmail.com
Fri Jan 9 01:39:43 EST 2009
This is an interesting proposition.
I have wanted for a long time to reform the way we do destroy().
Specifically
I've wanted to go through and make a patch replacing all the
    this.propX = null;
with
    delete this.propX;
...but have sort of just never gotten around to it.
as for the proposition here, two thoughts:
1) overriding the valueOf() thing makes me a little nervous. It seems like
this is the main reason for you suggesting this in the first place, and I
can see how this would be handy... but my gut reaction is that having to
special case our code to deal with a variable that has possibly been
destroy()ed... it sounds like that's not a situation we'd ever want to be
in. the response to that might be "keep on dreamin' uz, have you looked at
the code lately?" and i'm happy to stomach that ;-).... but seriously, in my
mind, the destroy() call in my mind should only be happenning when the
variable in question is absolutely no longer needed. which to me means that
there should never be code calling it at that point. maybe there are some
cases i'm not thinking of (event callbacks?) but anyways, just a gut
feeling. as always, more than happy to be convinced otherwise.
2) there is the issue here of objects-with-objects. like when you have an
obj 'foo' which has a property 'bar', which is also an object. what to do in
that case? do we want to make this recursive? base case (obj has no
properties or typeof obj is simple base type) return, and otherwise
recursively call OL.Object.destroy() on every (typeof object) property? it
goes without saying how that can be a dangerous black hole. keeping it as is
below, however, has the danger of orphaning (?) a bunch of memory. is there
any way to satisfy both?
anyways, destroy() reform is a fun topic and i'd love to hear what others
have to say.
good suggestion, tim.
ups,
e
On Thu, Jan 8, 2009 at 18:56, Tim Schaub <tschaub at opengeo.org> wrote:
> Hey-
> We don't currently have a uniform way of determining if an OpenLayers
> object has been "destroyed".  I'm wondering what people think of adding
> something like this:
> OpenLayers.Object.destroy = function(obj) {
>     for(var prop in obj) {
>         delete obj[prop];
>     obj.valueOf = function() {
>         return false;
> Then we could use the following to decide if something has already been
> destroyed:
> obj == false // true after OpenLayers.Object.destroy(obj)
> Benefits:
> We'd have a uniform way of determining if the destroy method had been
> called.
> Drawbacks:
> This only works for the level of type coercion done by the equality
> operator.  The logical not operator still considers the object truthy
> (so !OpenLayers.Object.destroy(obj) === false).  So, we'd probably still
> end up doing things like this (to test undefined or destroyed):
> if(obj && obj != false) {...}
> Also, maybe we're better off checking explicitly for properties as we do
> currently (!obj.events etc.)
> Any opinions?
> Tim
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090109/824f91bb/attachment.html
More information about the Dev mailing list
