[OpenLayers-Dev] OpenLayers.Strategy.Grid
Eric Lemoine eric.c2c at gmail.com
Tue Jan 13 02:36:59 EST 2009
Hi Zac
I'm not too familiar with TMS but what's the point of using TMS-like
URLs if a bbox param is used?
I guess having what you want could be implemented with a new protocol
(possibly inhereting from HTTP). That protocol would infer the URL
path based on the BBOX filter.
Eric
2009/1/13, Zac Spitzer <zac.spitzer at gmail.com>:
> Hi Eric,
> I just found that myself :)
> how hard would it be to get this to produce TMS tile like urls with
> the bbox as a parameter?
> ie something along the lines of
> /2/2/1.js?bbox=154.82048115388346,-36.127010141571624,156.97859137665813,-33.96889991879695
> then having a .htaccess which triggers the generation of the file when
> it doesn't exist
> looks like once the url for the file path is calculated it just needs to be
> passed as an extra option into requestFeatures ?
> z
> On Tue, Jan 13, 2009 at 5:21 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>> Zac
>> I'm glad you like it :-)
>> You can try the following: in Strategy.Grid make the "value" of the
>> created filter be an OpenLayers.Bounds instead of an
>> OpenLayers.Geometry.Rectangle.
>> Feel free to contact me again on the mailing list if you have further
>> question.
>> Cheers,
>> Eric
>>> I have been playing around with OpenLayers.Strategy.Grid from the
>>> vector behavior sandbox
>>> and it's really quite cool!
>>> I tried to add it in with the trunk but it seems there are some
>>> additional mods else where beyond
>>> OpenLayers/Grid.js
>>> OpenLayers/Strategy/Grid.js
>>> namely an error with  "options.filter.value.toArray is not a function"
>>> any tips?
>>> Zac Spitzer -
>>> http://zacster.blogspot.com
>>> +61 405 847 168
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
> Zac Spitzer -
> +61 405 847 168
More information about the Dev mailing list
