[OpenLayers-Dev] Ticket #1093
Zac Spitzer zac.spitzer at gmail.com
Thu Jan 29 04:18:23 EST 2009
when asking for a review, it's not so much to ask for your patch to
be uploaded to the ticket so that it can be viewed in line via trac
you say yourself it's easy to patch, then just upload it yourself!
plus your patch is mapserver specific and you modify the base class
in the inline patch...
chris is just asking for a specific patch against mapserver rather than grid?
code speaks louder than words....
z
On Thu, Jan 29, 2009 at 6:32 PM, Patrick Valsecchi
<patrick.valsecchi at camptocamp.com> wrote:
> Hi,
> About this ticket:
> http://trac.openlayers.org/ticket/1093
> I see there are a few missunderstanding. So I'll try to answer to your last
> comment.
> 1) The quote patch unquote scandal
> I tend to put the two liners inline because that way, I don't have to create a
> file, attach it to the ticket and you, you don't have to click on the
> attachment, click on "raw", save the file, go to your shell and apply the
> patch.
> Did you know that commands comming from the UNIX world tend to expect the data
> to come from STDIN when no file is specified? That way, you can just
> type "patch -p0", press enter, cut&paste the quote patch unquote in your
> shell, press enter and finally CTRL+D.
> I think it's easier that way for both of us. Don't you?
> 2) The lack of final patch from me
> In your "10/17/07 09:40:58" comment, you said you wanted to see with the
> MapServer developers first. Since it's a pain in the ass for me to write OL
> patches, I was waiting for the result of this.
> Why is it so hard for me to write a patch? In the past, all the OL patch I
> submitted where either rejected or took ages to be committed. Since I need
> the correction fast to be able to move forward in my job, I have to first
> change the buggy methods using javascript overriding. That way i can do the
> work I'm paid for. Then, I write a ticket, modify the OL code to create a
> patch. After that, i have to go through the pain to argue why I've used
> solution A instead of B, apply some unwroten coding convention to my patch (a
> missing space here and there) and, maybe, after a few patch versions and a
> couple of month of arguing, the modification appears on SVN. Then, I have to
> remove my "JS override" patch from my code.
> You'll ask me why I don't use a sandbox? My answer to that is: because of some
> un-written rule in my campany.
> Why do I still go through the pain to write OL tickets? First because my boss
> asks me to, then to try to help the other OL users.
> Why don't I write a correct patch first? Because I'm too stupid.
> Why is this process so long? I'll let you answer to that one. I've submitted
> patches to a lot of other OSS projects and OL is the most painful.
> Have a nice day.
> Patrick Valsecchi
> Senior Software Engineer
> Camptocamp Suisse SA
> http://www.camptocamp.com
> +41 21 619 1030
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the Dev mailing list
