[OpenLayers-Dev] Openlayers with Mapguide
Zac Spitzer zac.spitzer at gmail.com
Wed Jul 1 00:00:31 EDT 2009
you need to set both these values to match your map,
var mapBounds = new
OpenLayers.Bounds(-87.764986990963,43.691398128788,-87.6955215109,43.79752000048);
var fixedScales
=[1000,1930.6977300000001,3727.5937199999998,7196.8567300000004,13894.95494,26826.95795,51794.746789999997,100000];
On Wed, Jul 1, 2009 at 1:58 PM, ehsan<ehsan85 at yahoo.com> wrote:
> I'm using the mapguide 2.0,
> for the pink image layer (the layer does not show),i use the tiled map
> when i right click and view the image it's show:
> Index is out of range.
> Exception occurred in method MgMapBase.GetFiniteDisplayScaleAt at line 283
> in file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\platformbase\MapLayer/MapBase.cpp
> zspitzer wrote:
>> You need to dive in and find out what the the error was...
>> Which version of mapguide are you using?
>> What did the mapguide server error log say?
>> try right clicking on a pink tile and view the image
>> z
>> On Wed, Jul 1, 2009 at 10:47 AM, ehsan<ehsan85 at yahoo.com> wrote:
>>> Hi, i need help on getting started openlayer with mapguide..?any link
>>> that i
>>> can use to learn...i'm still new with mapguide and OpenLayer..
>>> i just download the OpenLayers-2.8 and sheboygan.php from the code sample
>>> at
>>> https://trac.osgeo.org/mapguide/attachment/wiki/CodeSamples/JavaScript/OpenlayersExample/sheboygan.php
>>> i try to change map layer defination from the sheboygan.php code, but the
>>> layer does not appear, it just came out with pink layer...any body
>>> help..?
>>> Thanks,
>>> ehsan.
>>> View this message in context:
>>> http://n2.nabble.com/Openlayers-with-Mapguide-tp3186274p3186274.html
>>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
>> Dev mailing list
> View this message in context: http://n2.nabble.com/Openlayers-with-Mapguide-tp3186274p3186965.html
> Dev mailing list
Zac Spitzer -
+61 405 847 168
More information about the Dev mailing list
