[OpenLayers-Dev] Openlayers with Mapguide
ehsan ehsan85 at yahoo.com
Wed Jul 1 00:16:30 EDT 2009
i just set both the value, but it is still come out with the pink image when
i click on the GetTileImage..
when i right click on the imge, it show the same error..
zspitzer wrote:
> you need to set both these values to match your map,
> var mapBounds = new
> OpenLayers.Bounds(-87.764986990963,43.691398128788,-87.6955215109,43.79752000048);
> var fixedScales
> =[1000,1930.6977300000001,3727.5937199999998,7196.8567300000004,13894.95494,26826.95795,51794.746789999997,100000];
> On Wed, Jul 1, 2009 at 1:58 PM, ehsan<ehsan85 at yahoo.com> wrote:
>> I'm using the mapguide 2.0,
>> for the pink image layer (the layer does not show),i use the tiled map
>> when i right click and view the image it's show:
>> Index is out of range.
>> Exception occurred in method MgMapBase.GetFiniteDisplayScaleAt at line
>> 283
>> in file
>> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\platformbase\MapLayer/MapBase.cpp
>> zspitzer wrote:
>>> You need to dive in and find out what the the error was...
>>> Which version of mapguide are you using?
>>> What did the mapguide server error log say?
>>> try right clicking on a pink tile and view the image
>>> z
>>> On Wed, Jul 1, 2009 at 10:47 AM, ehsan<ehsan85 at yahoo.com> wrote:
>>>> Hi, i need help on getting started openlayer with mapguide..?any link
>>>> that i
>>>> can use to learn...i'm still new with mapguide and OpenLayer..
>>>> i just download the OpenLayers-2.8 and sheboygan.php from the code
>>>> sample
>>>> at
>>>> https://trac.osgeo.org/mapguide/attachment/wiki/CodeSamples/JavaScript/OpenlayersExample/sheboygan.php
>>>> i try to change map layer defination from the sheboygan.php code, but
>>>> the
>>>> layer does not appear, it just came out with pink layer...any body
>>>> help..?
>>>> Thanks,
>>>> ehsan.
>>>> View this message in context:
>>>> http://n2.nabble.com/Openlayers-with-Mapguide-tp3186274p3186274.html
>>>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
>>> Zac Spitzer -
>>> http://zacster.blogspot.com
>>> +61 405 847 168
>>> Dev mailing list
>> http://n2.nabble.com/Openlayers-with-Mapguide-tp3186274p3186965.html
>> Dev mailing list
> Zac Spitzer -
> +61 405 847 168
> Dev mailing list
View this message in context: http://n2.nabble.com/Openlayers-with-Mapguide-tp3186274p3187029.html
More information about the Dev mailing list
