[OpenLayers-Dev] is beforefeatureadded working properly?
Andreas Hocevar ahocevar at opengeo.org
Wed Jul 1 14:40:50 EDT 2009
On Wed, Jul 1, 2009 at 6:42 PM, Esteban olm<esteban.olm at gmail.com> wrote:
> Hi,
> I have something like:
>         var MLayerTemp =(...) //New vertor layer
>         MLayerTemp.events.register("beforefeatureadded", MLayerTemp,
>             function(MElemento){
>                 MElemento.object.removeFeatures([MElemento.feature]);
>                 MElemento.object.destroyFeatures();
>                 return true;
> //And then  I add the OpenLayers.Control.DrawFeature to the map
> The problem is that whe the event function is called, the feature is not in
> the screen map, but it is in the features array of the layer.
You are right, this is a bit odd. You can register for the
"beforefeaturesadded" event instead, this gets triggered before
features are added to the features array.
> So the problem is:
>  If I need to delete all features before inserting the new one, I can not do
> something like:
>                 return true;
> Becouse this erases also the new feature I try to insert!!
> Is it normal that the new feature to insert is already in the feature
> layers' Array?
> I think it shoul not to be in the array, so we have not decided yet if it
> can be inserted or not.
> Anyway, another problem: If I return false... The feature is inserted!!!
> The documentatio says it should not be inserted.
Right. Also odd. It is inserted, but not drawn on the map. Maybe you
want to create a ticket and report this issue?
(http://trac.openlayers.org/wiki/HowToFileTickets)
Regards,
Andreas.
> Any help will be appreciated,
> Thanks
>    Esteban Olm
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
