[OpenLayers-Dev] Format.WMC questions
    Andreas Hocevar
    ahocevar at opengeo.org
    Sat Jul 11 16:23:21 EDT 2009
Hi Trond,
thanks for your work! read_wmc_LatLonBoundingBox can safely be removed.
For the *URL nodes, I would prefer a common method. If you look at the
WMC schema (http://schemas.opengis.net/context/1.1.0/context.xsd), you
will see that there is a URLType. All URLType nodes could use the same
reader function, and since runChildNodes adds some overhead, I would
prefer this function like e.g. read_wmc_LegendType.
So we would have something like:
    readURLType: function(node) {
        var obj = {
            width: node.getAttribute('width'),
            height: node.getAttribute('height')
        var links = node.getElementsByTagName("OnlineResource");
        if(links.length > 0) {
            this.read_wmc_OnlineResource(obj, links[0]);
        return obj;
    read_wmc_LegendURL: function(style, node) {
        var legend = readURLType(node);
        style.legend = legend;
Regards,
Andreas.
Trond Michelsen wrote:
> I'm currently working on adding parsing and writing of the remaining
> elements of Web Map Context documents, and there's something here that
> caught my eye.
> In read_wmc_MetaDataURL and read_wmc_LegendURL, the content of the
> OnlineResource element is read like this:
>     this.read_wmc_OnlineResource(legend, links[0]);
> But afaict, this.runChildNodes(legend, node); should do the same. The
> only difference would be if there are more than one OnlineResource
> elements within the LegendURL og MetaDataURL elements, and there
> shouldn't be.
> Are there any particular reasons why these methods don't just call
> runChildNodes()? Should the methods for LogoURL, DescriptionURL and
> DataURL read the OnlineResource the same way, or is it OK that I use
> runChildNodes() in all methods?
> Also, there's a read_wmc_LatLonBoundingBox() method, but I can't find
> any LatLonBoundingBox element in the WMC standard. If it's OK, I'll
> just delete this method.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
