[OpenLayers-Dev] DeleteFeature control
Alexandre Dube adube at mapgears.com
Tue Jul 21 08:35:47 EDT 2009
Oh and by the way, here's what I did for the Control (attached).  Is it
ok (too much, i.e. about the use of hasOwnProperty functions) ?
Thanks,
Alexandre
Alexandre Dube wrote:
> Eric Lemoine wrote:
>> so, to get to the delete control you've been working on, I see more
>> value, in terms of flexibility, in adding "control composition" to the
>> control base class.
> I also agree.  Originally, the control had a Feature handler instead of
> a SelectFeature control.  Looking at it now, it's too simple to be
> justified as a new control.
>>>> About the 'controls' property and the act./dea. automatism : that's a good idea, but wouldn't it be good to have a 'handlers' property also and activate/deactivate all handlers as well ?  Currently, control has a 'handler' property only.  Would it make sense to have 'handlers' added a do the same kind of automatism as the new 'controls' property ?
>> Agreed.
> Great.
Alexandre Dubé
Mapgears
www.mapgears.com
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090721/6a8402ec/control.bin
More information about the Dev mailing list
