[OpenLayers-Dev] DeleteFeature control
Eric Lemoine eric.lemoine at camptocamp.com
Thu Jul 23 02:19:22 EDT 2009
On Wed, Jul 22, 2009 at 7:22 PM, Alexandre Dube<adube at mapgears.com> wrote:
> Eric Lemoine wrote:
>> Alexandre
>> I now understand one of your problems, you need to give the handler a
>> reference to the control, but the control does not exist yet since
>> you're actually creating it. Giving the handler a fake control, of the
>> form {map: map} (where map is the map instance) should do the trick.
>> I think handlers do not actually require a reference to the control,
>> they just need a reference to the map (to register listeners). So I
>> don't understand why we have this constraint. Anyone involved in the
>> design of handlers knows?
> Mmm... I understand, but since I need to use callbacks on "handler" events,
> I think it's simpler to create my control the way I already did it.  I won't
> go any further in this example.
Ok.
> I still agree with automatic controls and handlers activation/deactivation.
>  Attached an new patch with the simple changes needed.  Is it ok ?  If it
> is, I'll open a ticket.
Ok to me.
Thanks Alexandre,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
