[OpenLayers-Dev] WMSGetFeatureInfo ctrl "format" parameter missing
Tim Schaub tschaub at opengeo.org
Fri Jul 24 18:08:39 EDT 2009
Hey-
Alexandre Dube wrote:
> Hi,
>  One of my coworker had some trouble using the WMSGetFeatureInfo
> control.  The response always said "Missing FORMAT property".  Here's
> what he found on this :
> Section 7.3.1 of the WMS 1.1.1 specification says:
> "Because the WMS protocol is stateless, the GetFeatureInfo request
> indicates to the WMS what map the user is viewing by including most of
> the original GetMap request parameters (all but VERSION and REQUEST)."
> So, even if the FORMAT parameter is meaningless in the context of a
> GetFeatureInfo request, according to the spec it is a required parameter
> (as per section 7.2.2) and should be included by OpenLayers in its
> GetFeatureInfo requests.
> What do you think ?
This is correct.
http://trac.openlayers.org/ticket/2201
Tim
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev mailing list
