[OpenLayers-Dev] RC5 prop
Andreas Hocevar ahocevar at opengeo.org
Mon Jun 1 06:56:36 EDT 2009
Now that another regression was found
(http://trac.openlayers.org/ticket/2115, currently set to Review),
there is at least one more reason :-).
Thanks,
Andreas.
On Sat, May 30, 2009 at 10:54 PM, Christopher Schmidt
<crschmidt at metacarta.com> wrote:
> On Sat, May 30, 2009 at 10:28:50PM +0200, Eric Lemoine wrote:
>> On Friday, May 29, 2009, Christopher Schmidt <crschmidt at metacarta.com> wrote:
>> > So, Pierre and Andreas worked out:
>> >   http://trac.openlayers.org/ticket/1797#comment:22
>> > To likely be a Google API change.  As I understand it, this:
>> >     * CHanged something that worked when we fixed it, to something that
>> >       didn't
>> >     * Was a change due to a GMaps API change
>> >     * Was something that we put a lot of effort into fixing
>> >     * Affects MapFish/GeoExt (and probably other JS Frameworks with
>> >     * flexible map sizes)
>> > As a result, I think it's worth including in 2.8: It was worth it the
>> > first time, it's still worth it this time (even though we aren't
>> > responsible for the regression, we've still got to deal with it.)
>> > IF this ticket doesn't affect people (I think it does -- i just emailed
>> > the geoext list about it, and pierre bumped into it, after all) then we
>> > can bump it, but otherwise, it's worth another RC.
>> > So, if anyone else agrees with me -- and I'd especially like to hear
>> > from GeoExt or MapFish people who can confirm that this is actually an
>> > issue, and is now fixed -- then I say I roll an RC5 this afternoon.
>> It indeed affects GeoExt - Google layers within a map panel do not
>> display. I'll test Andreas' latest patch on Tuesday (said Monday in
>> the ticket but realized Monday is off for me) and will report back in
>> the ticket.
> Well, a GeoExt user was able to confirm that 2.8-rc4 did not work, and
> using Google.js from trunk did, so I'm happy enough saying that this has
> been tested with GeoExt for the problem reported.
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
